Old 02-06-2009, 19:49
FIRE FIRE is offline
Nieuw technisch reglement voor BTCC vanaf 2011: Next Generation Touring Car
Alan Gow heeft vandaag een nieuwe technisch reglement gepubliceerd:
Technical overview: NGTC
The BTCC has released details of its ‘Next Generation Touring Car’ (NGTC), to be introduced from 2011. The introduction of these new technical regulations are designed to fulfil the following criteria:
• Dramatically reduce the design, build and running costs of the cars and engines
• Maintain present levels of performance until 2013, to ensure performance parity with current S2000 cars
• Reduce the potential for significant performance disparities between cars
• ‘Future proof’ the regulations by being able to easily modify the various performance parameters
• Reduce reliance on WTCC/S2000 equipment, due to increasing costs/complexity and concerns as to its future sustainability/direction
Brief Specifications:
• Front-wheel-drive
• 2-litre turbocharged production-based 4-cylinder petrol engine, producing approx. 300bhp with a 7,000 rev limit, 0.8 bar of boost and inlet-restrictor.
• 6-speed sequential semi-automatic gearbox
• Increased minimum length of 4.4m
• Standardised width of 1875mm
• 2, 3, 4 or 5 door – providing they share the same basic silhouette and dimensions as the 4/5 door saloon version
• Fully adjustable subframe-mounted front & rear suspension
• Larger wheels/tyres
• Common major components to be utilised; such as ECU, gearbox, brakes, hubs, steering rack, fuel tank and etc.
• Integrated front aerodynamics to incorporate radiators, cooling ducts and partial flat-floor to a given design parameter/dimension. Specified rear wing profile and size. Each car to be wind-tunnel tested to achieve similar aero equality
• Increased driver safety
• Stronger and more robust major components with full at-event parts supply service and support
• Lower C02 emissions output than current
Chassis
Production bodyshell with a standardised roll cage design/specification. Front & rear subframes to incorporate specified suspension/brake components and engine location.
Bespoke TOCA-sourced components for some major items such as gearbox, suspension, brakes, dampers, sub-frames and suchlike – thus taking tens of thousands of pounds out of the costs of designing and developing these for each team.
Teams will have far less of their capital tied up through not having to maintain a large spares inventory – the major component suppliers will maintain a sufficient level of inventory to service the teams.
Car design/development/build costs will be reduced by some 50 per cent from current – with an achievable target price of £100k per car ‘ready to race’, plus engine. (A new S2000 car can cost in excess of £200k).
Engine
The base engine can be sourced from a manufacturer’s broad ‘family’, including subsidiary brands under their effective control, with the bore/stroke allowed to be altered to achieve the 2-litre displacement.
Items such as camshafts, pistons, dry sump, inlet and exhaust system systems will be free (within set parameters). A 'Technical Review Panel' may review any individual applications to redesign some standard engine components, but only for reliability purposes.
A specified turbo, wastegate, intercoolers, injectors and ECU (engine control unit) will be mandated to reduce development costs and opportunities for technical infringements.
Each new engine developed will be tested on a TOCA-nominated engine dynamometer to monitor output levels.
Even though the new engine will produce more power/torque, the engine development and costs will be dramatically reduced by over 50 per cent from current, with new engines costing around £15k each (after initial development costs). An engine should last a full season without requiring a rebuild, in normal use, with a rebuild cost of around £8k at season’s end.
A ‘TOCA’ (i.e. unbranded) NGTC engine will be commissioned and available to those teams who do not wish to undertake their own individual engine development programme. These will be available at a fixed cost per engine of £25k a year (leased with full at-event support service) or £20k to purchase. Engine rebuilds will cost £8k. This TOCA engine may also be available for use in upgrading S2000 cars in the future, to reduce engine costs for those teams and extend the competitive life of their current cars.
Performance Parity
A policy of equivalence in overall performance between the current S2000 and the ‘Next-Gen’ cars will be maintained until 2013, to provide asset protection for the S2000 cars and parity of competition throughout that period.
In simple terms, the two specifications of cars will be equally eligible for outright honours – and be equivalent in overall performance – until 2013.
From 2013, whilst S2000 cars will still be eligible, the ‘Next-Gen’ cars/engines will then be progressively increased in performance and a turbo ‘over-boost’ facility be incorporated to allow a regulated amount of short power boosts during each race.
Stability of the new technical regulations will be maintained for at least five years (i.e. to the end of 2016), when they may be reviewed. However, it is the clear intention that the fundamental aspects of these regulations will continue well beyond those first five years and will not be substantially altered beyond minor updates (if appropriate).
In all likelihood, the older BTC-spec cars will cease to be eligible from 2011 – although this is yet to be confirmed.
Gow answers NGTC questions
btcc.net has put five key questions to BTCC Series Director Alan Gow after it was announced that in 2011 the championship will move towards a new set of technical regulations.
1. Why the switch to turbo-charged engines?
“They will produce more power and yet be easier to manage in terms of adjusting their performance characteristics – particularly with the common components and controls we will put in place – whilst not being an ‘over-stressed’ engine. Hence, they will be very durable and reduce the engine costs for the teams by a massive amount. Many manufacturers produce 2-litre engines of this type and for those that don’t, we’ll allow teams to alter the bore/stroke in order to achieve the two-litre litre capacity – which also means there is a greater choice of cars/engines for the teams to use than at present.”
2. Why permit only front-wheel-drive cars under the NGTC regulations – doesn’t this exclude traditional rear-wheel-drive makes, such as BMW?
“The reality is that the BTCC has not had a rear-wheel-drive manufacturer team for some 14 years so it just doesn’t make sense to compromise a set of new, very clear technical regulations (and bring in other major issues of parity) just for the very remote possibility of perhaps including one manufacturer. Similar reasoning applies as to why diesel engines also won’t be eligible; these regulations are designed to achieve a fair and ‘level playing field’, so therefore won’t be subjected to endless technical and sporting arguments as to the equality of some cars.
“The vast majority of manufacturers produce front-wheel-drive cars that fit these regulations, so all the teams will have a huge variety of differing makes/models to choose from. Besides, the S2000 BMWs currently in the series will continue – and on an entirely equal footing with the NGTC cars – for another three seasons.
“In fact, all the current S2000 cars will be put on a performance parity with the NGTC cars until 2013 so the teams who are using S2000 cars know they’re not suddenly going to be forced to sell them. However, realistically, by the time 2013 comes around it’s unlikely that the top teams (with existing S2000 cars) would still be using the same cars they have now, as the cars would be getting on a bit in race-car terms.”
3. Why bigger cars (the minimum length has increased to 4.4 metres)?
“Most fans would say that they would prefer the BTCC cars to be larger, faster and thus a bit more exciting than they are now. Well, these regulations deliver all that, and more. I think it’s widely agreed that the larger BTCC cars are preferable to, say, smaller hatchbacks. They are more in line with the meaning of a ‘touring car’ – they have greater presence and are more visually appealing. And, as production cars are getting larger all the time, it will give the championship a fabulous diversity of cars.”
4. Have you come up with the NGTC based on any influence from any manufacturers that might be ‘waiting in the wings’?
“No. The NGTC regulations have been developed with direct input from our teams, who had an intricate role in drawing up the regs over the last few months. However, these regulations provide the opportunity for either independent or manufacturer-backed teams to design/build and compete on a much more equal basis (and for far less money!) than they do now.”
5. How strong a set of regulations are these going to be compared to those used in other major touring car series, eg. WTCC?
“Incredibly strong. These are a bloody clever set of regulations put together by some of the most talented touring car engineers around. I know the WTCC is looking into a different (but much more expensive) turbo engine formula but it may not be very widely attractive, as it still relies on some deep-pocketed manufacturers to underwrite the programme.
“Manufacturers, sponsors and teams are all looking for very major cost savings/value for money in their motorsport programmes. With our new NGTC regulations, those major homologation/origination/development costs have been ripped right out of the equation. So I wouldn’t be surprised if some other national touring car championships, currently using S2000, don’t also look at what we have done with our new regulations…”
Bron: Officiele website BTCC
Ziet er interessant uit, maar moet het nog beter lezen om een echte mening te kunnen vormen.
Old 02-06-2009, 20:30
smiley's Avatar
smiley smiley is offline
Op het eerste zicht lijken me dat wel leuke regels.
Te hopen keert vauxhall dan al met de insignia terug *wishfull thinking*
Achja met een prive initiatief van 888 ben ik al blij genoeg :P
Old 02-06-2009, 21:02
Mark's Avatar
Mark Mark is offline
Pain in the Ass :)
De Britten maken hun woorden waar, die hebben dus schijt aan de nieuwe plannen van de FIA voor het WTCC vanaf 2011. E.e.a. stond reeds "voorzichtig" te lezen in de Autosport van afgelopen week.
Old 02-06-2009, 21:07
Een groot pluspunt is dat we in ieder geval grotere wagens gaan zien en dus automatisch sedans i.p.v. hatchbacks.
Enige wat me niet bevalt is dat RWD uitgesloten is van deelname. BMW hoort naar mijn mening toch echt thuis in toerwagens en om die nu uit te gaan sluiten? Super Touring heeft bewezen dat het wel mogelijk is om met FWD en RWD wagens samen te racen, zeker als dat allemaal saloons zijn.
De tijd zal uitwijzen of de kosten echt beperkt blijven tot 115.000 Euro en of fabrikanten en teams daadwerkelijk wagens gaan bouwen. Het vorige eigen technische reglement (BTC-T) was geen succes. Ik denk dat Andy Gow moet gaan praten met organisatoren van andere kampioenschappen zoals STCC, DTC en misschien BTCS. Grootste reden waarom BTC-T mislukt is was denk ik het feit dat 1 kampioenschap te weinig basis is voor het ontwikkelen van wagens.
Ik ben benieuwd hoe de wagens er uit gaan zien. De BTC-T wagens vond ik niet echt mooi.
Overigens zou ik dit reglement wel willen zien in DTM, echter dan met circa 400 tot 450 pk sterke (turbo) motoren en RWD of AWD. Mercedes C-klasse, BMW 3-Serie, Audi A4, Lexus IS, Infiniti G37, Opel Insignia, Ford Mondeo....
Old 02-06-2009, 21:09
Is natuurlijk te prijzen dat ze zelf met plannen komen, echter de vorige keer dat ze schijt aan de FIA hadden was geen succes. Het is dus afwachten of het dit keer wel lukt.
Old 03-06-2009, 18:26
smiley's Avatar
Ik vond ze wel wat heben, de astra coupe, de mg zs, de de integra de hatchback's waren wel wat minder knap.
Als ze bij de DTM meer merken willen moeten ze dringend de regels gaan veranderen. Ten om de kostprijs van de nieuwe wagens lager te maken. Maar vooral zodat iedereen vanaf 0 start, om nu als nieuw merk in de dtm te stappen is gekkewerk. Audi en Mercedes zitten al 10 jaar met die regels te werken. En in de dtm laten ze niet ineens allemaal ristrictie vallen als je niet meekan met de top. Dan is een intrede in het wtcc veel interesanter als nieuw merk.
Old 09-09-2010, 18:47
http://www.touringcartimes.com/article.php?id=5250
Zie er prima uit!
Old 09-09-2010, 20:01
Pegasus's Avatar
Pegasus Pegasus is offline
Knap idd! Ik ben aanwezig in Brands Hatch dat weekend dus laat maar komen
Old 09-10-2010, 13:55
http://www.touringcartimes.com/article.php?id=5382
Ziet eruit als een echte toerwagen, al is er weinig tot geen optische verschil met S2000. Voor de uitstraling moet de grootste winst komen uit het feit dat grotere wagens, en dus sedans, verplicht worden.
Old 09-10-2010, 15:35
tarzancorner's Avatar
tarzancorner tarzancorner is offline
Een lekkere strakke bak ik hoop dat de DTM ook mee kijkt hoe een echte toerwagen er uit moet zien niet van de rare spoiler, deuren die er normaal uit zien etc.
Old 09-10-2010, 17:13
Dit (post #44) zou DTM moeten doen maar dan met een 450 pk sterke V8.
Old 11-10-2010, 17:04
Pegasus's Avatar
Best wel de moeite die NGTC. Ik heb James Thompson er afgelopen weekend mee aan het werk gezien in Brands Hatch. Hij zat op ongeveer 1 seconde van de pole tijd van Jason Plato.
Foto's: www.motorsportshooters.com
Grtz
Old 13-10-2010, 19:09
De Scandinavische variant van NGTC:
http://www.touringcartimes.com/article.php?id=5411
