Go Back   De Paddock > Autosport > Eenzitters
Old 07-12-2002, 22:19
Raceboy's Avatar
Raceboy Raceboy is offline
formula mazda
Engine
240 HP Mazda “Renesis” rotary engine with encrypted ECU including rev limiter, pit speed limiter, traction control, ignition trim, fuel trim.
Tub
Carbon fiber composite built to FIA standards with 17 U.S. gallon fuel cell
Transmission
Six-speed sequential with no lift shift
Optional (subject to testing and rules review)
Data acquisition, including paddle shift on steering wheel, traction control defeat, ignition and fuel trim controls on steering wheel, pixel screen display, auto blip downshift
Suspension
Pushrod, inboard with two-way adjustable shock absorbers, adjustable rear sway bar, cockpit adjustable front sway bar. Front suspension tethered.
Bodywork
Fiberglass
Aerodynamics
Front wing and quick adjustable flaps of aluminum, rear wing two upper and one lower element of aluminum with composite end plates.
Brakes
Cockpit adjustable bias, 4-pot alloy calipers, vented, floating steel discs.
Cockpit safety
Anti-intrusion Kevlar panels, FIA headrest/side head restraint, compatible with HANS device.
Wheels
Front 9”w x 13”d, rear 11’w x 13”d, magnesium, center lock
Dimensions
Front track 61.5”, rear track 58.5”, wheelbase 101” and weight 1050 lbs.
helaas enkel in USA te vergelijken met een barber dodge.
Old 07-12-2002, 23:05
Scapa's Avatar
Scapa Scapa is offline
Net een formule 3...
Old 07-12-2002, 23:09
Raceboy's Avatar
ne formule 3 met airbox dan wel.
Old 07-12-2002, 23:36
Mark's Avatar
Mark Mark is offline
Pain in the Ass :)
lijkt nog het meeste op de Formula Palmer Audi.................
Old 08-12-2002, 20:34
Werner333's Avatar
Captain Paddock
Iedereen wil tegenwoordig zijn eigen eenzitter reeks zekers?
WWW.WERNER333.COM
